JUST BOUGHT
Old Jan 11, 2007 | 12:44 PM
95awdtsi's Avatar
Default JUST BOUGHT
[:@]a '95 talon awd. it's blowing smoke like crazy at idle. it really blows smoke when you are driving, but it tends to not blow as bad when you are driving a constant speed. but if you decrease speed for any reason, it's like a burnout contest! the turbo was replaced i was told. it looks brand new. i'm wondering if it's valve seals or the turbo wasn't properly installed? any advice would be highly appreciated!
Old Jan 11, 2007 | 12:54 PM
Default RE: JUST BOUGHT
what color smoke. Could be either oil or coolant
Old Jan 11, 2007 | 01:15 PM
95awdtsi's Avatar
it's oil without a doubt. the coolant stayed full. the oil was full when i left leesburg. i was driving home to orange county which is about 90 miles away. the oil light came on when i was pulling into my drive way. after letting the car sit awhile. i checked the ground for possible oil leaking spots and there weren't any. (newly built house, first owner)
Old Jan 11, 2007 | 01:31 PM
RCJr9186's Avatar
possible vavle stem seals or piston rings. . . that would be my guess for burning that much oil
Old Jan 11, 2007 | 01:38 PM
95awdtsi's Avatar
i was thinking along those lines also, i'm think about rebuilting the motor anyway! i'm checking out a couple of companies in the area. (jackson auto machine and dtm motorsports) but i really wasn't ready to do it right away.
Old Jan 11, 2007 | 02:16 PM
RCJr9186's Avatar
if you are just looking for a daily driver that is reliable you have a good car if you rebuild it or fix your problem. if you are looking for a speed demon. SELL THE CAR you won't get anymore than 150whp out of the car (on a dynojet) without spending at last 4k to turbo the car. trust me, i've been there.
Old Jan 11, 2007 | 02:28 PM
RCJ read his post he has a awd tsi . not a 420a. Jackson Auto Machine is a good place to go to. But the first thing i would do is a compression test on the cylinders. Its cheap and easy to do and that will let you know what problems you have
Old Jan 11, 2007 | 02:31 PM
95awdtsi's Avatar
hey chief...the car is already turbo charged. i plan on spending that amount on getting the motor degrease,and stroked. i just want to know if buy and install a new turbo, will that get rid of my problem. or do i have to send it to a shop to get the valve seals done.
Old Jan 11, 2007 | 02:39 PM
RCJr9186's Avatar
my bad, i was thinking about a different post and a different person. i don't think the turbo is your problem. sounds like something internal, like the rings or seals. if you are going to stroke it, you will need a larger turbo or you will be wasting your money, what did you have in mind?
Old Jan 11, 2007 | 02:41 PM
95awdtsi's Avatar
i've heard about doing a compression test! because i'm pretty sure that the man that wheni bought this car from, hesaid, that he had it done already. that's when the tech told him to buy a new turbo. i even have that stock turbo, and it has alot of shaft play. (forward & back)
