Key Fob
Old Jul 10, 2007 | 06:14 PM
willdue's Avatar
Default Key Fob
I tried the reseting of the key fob. But when i turn it to ACC and then back, the doors dont lock? But if i turn it to ACC and press the FOB, it works?
The black little plugin box on the right under the dash right?
Old Jul 10, 2007 | 06:37 PM
silvercoupe97's Avatar
Default RE: Key Fob
Did you do it according to the FAQ?
https://mitsubishiforum.com/m_101287/tm.htm ?
Yes, the connector is under the dash. Did you do this with all the doors closed?
Old Jul 10, 2007 | 10:04 PM
willdue's Avatar
Default RE: Key Fob
yep, all doors closed and i followed that write up
Old Jul 10, 2007 | 10:26 PM
Default RE: Key Fob
Check the jumper connections then. The locks should open and close on their own. The remote shouldn't matter at that point.
If all else fails, remove the remote's button battery, press and hold one of the buttons for a few seconds, let it sit for a few minutes, put the battery back (also make sure your remote battery isn't old), and retry the process.
I don't know why it didn't work with you and the only thing that can affect this is the jumper wire. That's the thing that tells the keyless brain that it's time to program.
Old Jul 10, 2007 | 10:46 PM
Dusty Eclipse's Avatar
Default RE: Key Fob
The fob DEF should not work with the car in ACC>
Old Jul 12, 2007 | 02:31 PM
willdue's Avatar
Default RE: Key Fob
yea, idk. Whats the jumper wire? It hasnt worked since my radio was installed
Old Jul 12, 2007 | 08:35 PM
Default RE: Key Fob
ORIGINAL: willdue
Huh? I thought you said you followed the how-to on this?
Was the radio install a DIY?
Old Jul 12, 2007 | 11:01 PM
willdue's Avatar
Default RE: Key Fob
you mean jumper wire as in the pin to hole 1&4?
Yes, i did it myself.
Old Jul 13, 2007 | 01:25 AM
Default RE: Key Fob
A jumper wire, such as the one that was used in the how-to (an everyday paper clip...I used a small spare wire I had in my toolbox).
Did you use a Metra wiring kit or similar? Are you sure the wires are wired up correctly? Kind of odd that your keyless/alarm stopped working correctly after the radio install, don't you think?
Old Jul 13, 2007 | 01:31 AM
Default RE: Key Fob
Pull the fuse for the radio, then check the fuse for your keyless and your power locks.... try it all again, and get back to us.
