Key Fob stopped working
Well my remote Key Fob stopped working today. So I intially thought it was the battery. I picked up a brand new one and nothing. I suppose the key fob could always be bad, but 1.) Is there any fuse that something else in the car that could not be working. 2.) If it is the fob, how do I go about getting it replaced?
ORIGINAL: Sebba
You need to reprogram it. Consult your owners manual... or call the dealership for instructions
Thanks that will bepretty helpful. Any ideas on how/if there is anyway to test if my fob is just bad? I'd hate to buy a new one if there is something else wrong.
Also, is there a good source for replacing the fob?
I'd check ebay under Eclipse/Talon/Avenger/Sebring. They use the same freqs and I've seen them in there every now and again.
A way to see if the the fob is working is by checking if the it lights up when a button is pressed. If you have one that doesn't have an LED indicator, then, there really isn't a way in DIY form other than trying to reprogram it.
shelles_diamante
Sep 1, 2006 07:56 PM
