Keyless Entry Installation
Old Jan 13, 2005 | 09:40 AM
Flipz's Avatar
Default Keyless Entry Installation
Hi,
I just found a installation guide for factory keyless entry installation on Mitsubishi Eclipse GS Spyder. Attached is the image. I have two questions about it:
1. Do you know where I could find a MB991529 tool to ground the terminal 1? (reference: http://www.realcaraudio.com/forums/p...threadid=47855)
2. Do you know where I could get a jumper wire; I am not sure how it looks like, can I get it from AutoZone or somewhere else?
Thank you in advance and I will be looking forward to hearing from you.
Best Regards,
Flipz
Old Jan 17, 2005 | 12:12 AM
customizedrides's Avatar
Default RE: Keyless Entry Installation
The specialty tool you can find a mitsubishi dealership or through snap on. As far as the jumper wire is concerned that is generally something you make. Just get a wire and strip both ends and then stick those ends where they're telling you to jump.
Old Jan 17, 2005 | 08:14 PM
1398spdr's Avatar
u can read that diagram??????
Old Jan 18, 2005 | 03:50 AM
Flipz's Avatar
Yeah, can't you?? Just zoom it via a photo editor if you cant ))
Old Jan 18, 2005 | 12:30 PM
1398spdr's Avatar
ok, now i can, i was a little drunk last night tryin to read that, but it makes sense now........
Old Jan 18, 2005 | 02:30 PM
Flipz's Avatar
Hey guys,
I will try this installation once I get back to my car but I was wondering one thing. With the key when I unlock the driver's door it is the only door that unlocks. I have to use the key by the door to unlock the other door. With the keyless entry installation when I click on unlock will both doors unlock or only the driver's side as with the key?
Thanks,
Svetlin
Old Jan 20, 2005 | 03:29 PM
vertstanggt's Avatar
both will probably unlock cuase it will probably tap into the power locks. So it will imitate pushing the unlock button in the car on the door which opens both.
Old Mar 4, 2006 | 12:13 AM
1qwkgst's Avatar
ok after searchin for a whole day i finally found somethin helpful and i wanna thank FLIPZ for da diagram and instructions on how to program the keyless entry remote . i read everyone's post and replys but no one seem to reply back on if it really worked or not until i tried it my self on my 95 gst and sure enough it works so once again thanx for everything.........
[IMG]local://upfiles/6973/E2A35FF98DC4419B8A9415BBE674DCA6.gif[/IMG]
Old Mar 20, 2006 | 12:40 AM
ketan2006's Avatar
so ur saying this may work
Old Mar 20, 2006 | 01:44 AM
ictponder's Avatar
I'm assuming your keys have a computer chip (anti-theft). If so, I think you have to have 2 keys in order to get it to work. BUT, maybe that's only if you want the new keyless entry to be programmed into your existing keyfab. I called about getting a Viper Keyless/Alarm/Remote Start installed in my car a few weeks ago, but they told me it can't be done since I only have 1 ignition key. So I say again, make sure it will work before ya spend the $$$. I hope it does work and that all this was a waste of words
BTW: I doubt you will have any trouble if you're just trying to install a factory keyles entry hehe
