kinda confused
Old Mar 28, 2007 | 01:37 PM
RCJr9186's Avatar
Default RE: kinda confused
i concure. i think the 2gb (with turbo spoiler)is by far one of the best looking cars on the road!!!!!
Old Mar 28, 2007 | 01:42 PM
brknhrtdpimp1489's Avatar
thats the one i used to have...2gb gst...thats it in my avatar lol so im going to do a conversion if i can stand this horrible car long enough to finish it...i had the power on this damn esi...its so gay...car looks good but not enough power for me...i want a gsx or a tsi awd...just cant find one...
Old Mar 28, 2007 | 03:10 PM
RCJr9186's Avatar
than you aren't looking very hard, you can search them on ebay, autotrader, dsmtuners . com, locally... they are all over.
Old Mar 28, 2007 | 03:40 PM
well i mean for like less than 5-6k...sorry i can find it just not for low enough for me to be able to afford...
Old Mar 28, 2007 | 03:55 PM
RCJr9186's Avatar
you can get a gsx shell on d s m t u n e r s . c o m for 2-3k
Old Mar 28, 2007 | 04:01 PM
yeah i know but if i can help it i wanna find a whole car for that or mabe just a little bit more...i know where theres a 95 gst for 2700 right now...doesnt run but i know whats wrong w/ it and i can fix it...
Old Mar 28, 2007 | 05:44 PM
RCJr9186's Avatar
good luck finding a good running gsx for under 4k... that's just dumb... that's like hoping to find a good running EVO IX for 10k.... just not going to happen unles you find 1 a complete idiot. 2 some rich dumby that doesn't care or 3 it's stolen or rigged.
Old Mar 28, 2007 | 09:40 PM
silvercoupe97's Avatar
ORIGINAL: brknhrtdpimp1489
it runs great when it decides to run lol the plugs are brand new i just changed them after i bought the car although i do have a slight idea of what could be the prob...when i was taking the old plugs out i noticed that the plug all the way to the right of the engine on the driver's side was covered in oil from the threads down...a buddy of mine said that this could just be b/c it sat for a while or b/c i have oil coming past my piston rings...idk i should prob check that plug again and see if its still doing it...sometime it will studder a little bit but that usually happens when it tries to die and then doesnt...never changed the wires yet though didnt really have the money to do it at the time...
Well, that's a starting point. You could have an arcing wire. Did you happen to notice arc marks on it anywhere on the boot or in the oily area? Did you happen to accidentally bump or move the CAS wires? They are on the right side too. Do you have the upper timing belt cover on or are you sporting the stock cams? The cam angle sensor is on the cam sprocket closest to the firewall. The cam and crank angle sensors sends the ECU ignition timing, without it, the motor will not get spark. Either or both will cause that btw.
Old Mar 28, 2007 | 10:44 PM
I Drive Naked's Avatar
Oil in the plug, check you valve cover gasket.
It has little oil seals around the plug holes.
As for it dying, but becoming alive again when you pop the clutch, this may be a long shot, but check the wiring of the clutch start switch.
Maybe somethings exposed causing a short.
Old Mar 29, 2007 | 09:33 PM
actually joshewuhh your not the first person to come up with that explanation...im starting to wonder if that might be a possibility...im about to sell the car i found a 95 gst for 2700 it has some minor probs but hell as long as the engine will turn over then i'll fix most anything else and worst things worst i'll part it and sell the shell ya know...anywayz i really need to pull that plug and see if it has oil on it again or if the new one is clean...
I Drive Naked
Jun 14, 2007 02:43 PM
white99rs
Sep 19, 2005 07:39 PM
vinceaton
Jul 7, 2005 07:41 PM
Cbluefrost
Apr 17, 2005 11:35 PM
