launching
Old Mar 17, 2005 | 08:50 PM
hawurd's Avatar
Default launching
whats the best way to launch and run an automatic GSX? (98 if it matters)
Old Mar 18, 2005 | 12:16 AM
DSMTalonAWD51's Avatar
Default RE: launching
Floor it. what else can you do? if you dont care about reaction time you could put it in neutral, rev it up an pop it into drive but im sure thats not good for the tranny
Old Mar 18, 2005 | 10:35 AM
get435's Avatar
when you pull up to the line or at a light push the gas and brakes but dont power brake just before the power break and when the light is green slam the gas and lets go of brake. works great in most auto cars/trucks.
Old Mar 18, 2005 | 05:27 PM
hawurd's Avatar
what should you rev too??
Old Mar 18, 2005 | 06:01 PM
theres no direct forumla for the perfect launch you need to go out there and practice. i ahve no idea about auto cars, but for manual awd cars a good point is around 4300-5300 rpms. start lower and see how the car does, if it boggs off the line ( kinda stutters), you need to rev higher to build more boost. if you go too high it will be pretty hard on your tranny though
Old Mar 18, 2005 | 06:24 PM
get435's Avatar
with the auto test it just the right amout of throtle to not power brake or move this will give you a quick launch i dont like to say this but the way i learned this trick is by being with my cuz when he raced a gsx in a drango and beat it. this made the launch amazingly fast seen him as well as others do it.
get435's Avatar
edit
Old Mar 18, 2005 | 08:14 PM
TurboDreamer's Avatar
the best way of launching an automatic cars without having problems with the gear box is pushing the throttle at the same time as breaks, look for the point that the car doesn't move and when you have the green light just let go the breaks
Old Nov 4, 2005 | 02:08 AM
hkjewop's Avatar
can someone explain the concept of power breaking. Becuase i floor it and hold the breaks to launch and it only revs to about 2200 RPMS and wont go any higher..
Old Nov 4, 2005 | 10:20 AM
eclipsed4u's Avatar
ORIGINAL: hkjewop
thats b/c your torque converter is a 2200 rpm stall torque converter. you don't need to rev it any higher as you will lose pressure in your brake lines. and this can be very dangerous.
if you want to rev higher, replace your torque converter with a higher stall torque converter.
BTW, what you do, its called power braking. so you already know how to do it.
Dragonslayer
Jun 25, 2006 03:03 PM
Mike21
May 30, 2006 10:36 PM
fourm1
Apr 11, 2006 02:10 AM
