Left motor mount Removal
Hello all. I am trying to remove the left motor mount on a 95 eclipse GS NT. I am having trouble as there is not enough room to remove the bolts. Does anyone have any suggestions? I have all the bolts loose and the engine is supported from underneath with a jack. The bolts are just to long but the book says that you can do this without removing the engine. Any help? Thanks a lot.
RE: Left motor mount Removal
dude hes not takin out the engine, hes just takin out the motor mount....tranvin77, you have a manual, like a Haynes or a Chilton? if not get one. i believe you have to take something out to take that one out. i would look in my book for you but im out of town and the book is 400 mi away. im sure one someone will let you know about it b4 i get home but if not ill let you know.
sometimes you gotta jack the engine up a little higher .. loosen all the of th bolts from the side of the motor and either let the jack way down or way up sometimes gives you room ot get a couple out, the rest have to come out with the mount , as long as theyre uscrewed all the way
if you still dont have room your car mighta been wrecked at one time
I have the book but it just says to remove the motor mount. I fully unbolted all 3 bolts but there is not enough room to remove them as they hit the fenderwell. I tried jacking the engine up but still no luck. How far can I jack the engine and still not break anything? Thanks for the help.
mlahrens
01-29-2016 06:54 AM
dvir
07-26-2012 09:15 AM
monteroshopper
10-15-2008 12:37 AM
