Light problem
Old Mar 3, 2007 | 11:22 AM
Nubiebubie_GSX's Avatar
Default Light problem
Yesterday driving back home my guage light, console light, side markers and rear lights went out. I know the bulb in all those didn't burn out because when i arm the alarm on my car all those blink and turn on. Can anybody help or had this problem before. I dont think its the rotating *** switch because i can still turn on and off my front head lights and high beam.
Old Mar 3, 2007 | 12:33 PM
Default RE: Light problem
Okay i went to check the fuse and found my tail lamp fuse burnt out so i replaced and all was working. Then as soon as i turn the key have the radio running and turn on the lights it blow the fuse again and there a burnt smell.. Still tryin to see wut causing this all of a sudden.
Old Mar 3, 2007 | 01:43 PM
TheAdvocate's Avatar
Most likely you have a barewire somewhere that is shorting out...
Old Mar 3, 2007 | 02:33 PM
Well i knew i smelt smoke from the engine bay area so i knew that area would be the culprit. Stuck in a larger fuse turn on the lights and look for smokes and it turned out my passenger side, side marker was the problem. Previous owner took out the mud guard to open up the intercooler and the bulb socket came out of the holding spot and was exposed to splashing water and shorted out the connection. But by doing the larger fuse i ended up melting the entire socket and blowing the bulb. Just cut the socket wiring and taped it all up shoved it back in and will be ordering a new socket.
jeedizzle
Oct 13, 2009 10:08 AM
shum_87
Aug 29, 2009 05:05 AM
pgb205
Jun 4, 2009 10:40 PM
EclipseFLAGirl
Nov 9, 2008 11:10 AM
serenabkhan
Nov 23, 2007 05:44 PM
