Light problem
Old Dec 3, 2007 | 05:41 PM
xdalittlemanx's Avatar
Default Light problem
Hey, I've got a 97 eclipse GST, and i recently replaced the stock headlights with a set of projectors. Everything was working fine, except I had to hook up the halos. So yesterday, I decided to hook up the halos, and I had already removed my corner lights from the bumpers, so I jsut had the wires there, so I hooked up the halo wires to the corner light wires. It worked fine at first, but then once I started driving, ALL the dash lights went out, so now i cant see my speed at night, and when I turn the lights on with the car off it doesnt make the obnoxious beep anymore to let me know my lights are on. Along with that, now when I turn my lights half on, just to the parking lights position, NOTHING comes on. I dont know if its a fuse, or a ground, or anything. Any ideas would help. Thanks a lot!
Old Dec 3, 2007 | 05:59 PM
TheAdvocate's Avatar
Default RE: Light problem
Most likely a fuse.. Just pull it out and check it..
Old Dec 3, 2007 | 07:43 PM
What fuse would it be?
Old Dec 3, 2007 | 07:44 PM
Who the hell knows. Random ones blow. Check em all! There is a box by the footwellon the drivers side and one under the hood.
Old Dec 3, 2007 | 09:18 PM
Haha, i tried a lot of them, and i didnt try any under the hood cause they were mostly headlights and breaks and engine stuff, i didnt see anything that would be for the instrument panel light thogh
Old Dec 5, 2007 | 10:06 AM
Boost_Bandaid's Avatar
Check your fuse in the engine bay thats labeled ( I think) Tail lights. When my cluster lights and interior went out it was that fuse. Weird how that fuse controlled the interior and dimmer switch. Anyways just go buy a 3 dollah fuse puller/detector from Autozone. Best investment i ever made
Old Dec 5, 2007 | 11:49 AM
Like i said.. CHECK THEM ALL
Old Dec 5, 2007 | 06:10 PM
Even if it doesnt look blown, change it anyways, because you cant always see it.. Should be a fuse labeled (HeadLamp) change that one..
Old Dec 5, 2007 | 06:32 PM
tjbiker031's Avatar
just use a light test to test ALL the fuses.
Old Dec 5, 2007 | 07:46 PM
Or a freakin volt meter with the short test. I forget what its really called.. i just know if the fuse is good it makes a sound lol
