lost power while driving!
Old Apr 17, 2010 | 01:59 PM
Envious7's Avatar
Default lost power while driving!
driving down the interstate and engine powered itself down. guages shut off. still have battery power.. when i try to start it back up it turns over but wont start. occasionally will start for a second back fire than shut itself off.. anyone help me out and let me know whats up with it??
96 eclipse 2.0l NT no mods.. jus intake and exhaust
Old Apr 17, 2010 | 04:44 PM
first check to see if you have spark. Then maybe check the fuel....you didnt run out of gas did you?
Old Apr 18, 2010 | 06:50 PM
Envious7's Avatar
I jus filled up so I got gas. Replaceed the camshaft position sensor changed plugs n wires.. only thing I haven done is changed the fuel pump or checked the fuel filter to see if its clogged. N I didn't check for. Spark but ill do that next.
Old Apr 20, 2010 | 08:34 PM
2slow's Avatar
o yo get power to the accesories or do you just have a charged battery?
Old Apr 20, 2010 | 10:13 PM
Envious7's Avatar
power to everything lights, radio, so ya i dunno
Old Apr 21, 2010 | 09:46 PM
Envious7's Avatar
i was told that my timing belt mite have skipped a tooth and my timing is off how can i fix that and could the timing belt tensioner be the issue?
Old Apr 22, 2010 | 07:19 AM
a tensioner could definetly cause this issue, but you are going to want to inspect the timing belt to verify that is the problem
Old Apr 22, 2010 | 08:23 PM
dsm1990gsx's Avatar
If your getting spark and fuel, perform a compression test.
Electech1
Nov 3, 2006 10:29 PM
vr4luver
Feb 24, 2006 01:19 AM
1997gsteclipse
Dec 8, 2005 03:10 PM
ron Kirk
Jul 31, 2005 01:45 PM
bdunn
Dec 1, 2004 03:38 PM
