Max HP possible?
Old Jul 27, 2006 | 12:08 AM
paintballproam's Avatar
Default Max HP possible?
If i were to take my 95 talon tsi awd, drop in
http://www.slowboyracing.com/more.php?id=1898&
And a much better turbo such as a garrett. What is the MAX hp i could achieve?????
Dont tell me it isnt worth it or any thing, my dad and i are thinking about is as a project for when i get out of uti
Old Jul 27, 2006 | 12:15 AM
Default RE: Max HP possible?
with like a 35r or a 42r you could probably achieve around 600hp-700hp depending on what turbo you get. That will easily get you very low 11's
Old Jul 27, 2006 | 04:24 AM
BrunoBoy650's Avatar
Damn..........i want that
Old Jul 27, 2006 | 12:24 PM
With a GT35R and a decent tune... with all the supporting mods. You can reach a little over 600hp with really quick spool up. The GT42R i would recomend for more of an automatic setup because you will get much more lag. However you can get over 700 from that turbo so its all about what you are really looking for.
Keep in mind that the engine will be just the beginning of your supporting mods. You will need a clutch, flywheel, fuel pump possibly a dual fuel pump setup, huge injectors, fuel rail, DSMLink, Intake manifold, decent exhaust manifold, FMIC, BOV, Possibly new front CVs and on top of that all the needed sensors and guages.
Old Jul 27, 2006 | 12:28 PM
ORIGINAL: Sebba
With a GT35R and a decent tune... with all the supporting mods. You can reach a little over 600hp with really quick spool up. The GT42R i would recomend for more of an automatic setup because you will get much more lag. However you can get over 700 from that turbo so its all about what you are really looking for. .
ummm where did you get this from??? the 35r on a stroker will spool at like 4000ish the 42r areound 5ish. why would you want an auto? I see EVO guys run 42rs on the street all the time with no spool issue. Keep in mind a built head will allow rev limit to be raised from 7500 to like 9000 or 8500. so full boost from 5000- 8500 is really good length of time whereyoucan make like 700+ hp
Old Jul 27, 2006 | 12:29 PM
According to Engineer it spools at 3k.
Old Jul 27, 2006 | 12:31 PM
ORIGINAL: Sebba
he doesnt even have a turbo car anymore lol. My 16G doesnt hit 20 PSI untill 3200 so why would a 35r spool 20+ PSI faster? other than the strocker but even still it will only spool for high 3000 rom range
Old Jul 27, 2006 | 12:32 PM
Ask him. Maybe cuz its dual BB
ORIGINAL: Sebba
i said that? I hope i didnt or else i'll have to smack myself in the face
Old Jul 27, 2006 | 12:35 PM
ORIGINAL: TheEngineer
actually for the max power output of the gt35r (which is around 600hp!!) it has unbelievably quick spool due to the dual ball bearings. I think they hit full spool up around the high 3000's which is pretty damn good i think, and there is NO WAY you could ever get this much HP out of a 16g.
