MBC?
Old Jul 20, 2006 | 05:26 PM
gstTurbo2011's Avatar
Default MBC?
I got my car off of a friend who owns a dealership.My car has a couple things done to it already which i liek and would of done anyway. Although i am not sure if i have a MBC.. I have aftermarket boost gauges. I'm only getting like 9-10 psi .i want like 12...now i've seen MBC's before and i think i have one..TELL me if i don't cuz i ain't a pro lol..thanks I have pictures of the MBC and my intake and BOV . i've seen other setups and mine seems different ..idk..i know you can't see everythign in these pics sry bout that.
Old Jul 20, 2006 | 05:27 PM
Default RE: MBC?
some more pics
Old Jul 20, 2006 | 05:30 PM
Default RE: MBC?
bov and intake
Old Jul 20, 2006 | 06:54 PM
Default RE: MBC?
A few things i have to comment about that...
1) That looks very much like a MBC although it looks like a crap one it should still do its job. To get more boost simply turn the screw clockwise very slightly... every MBC is different so be careful how much you turn it.
2) I notice you are venting your BOV (the pipe is dissconected from the BOV to the intake)... i strongly advise against that. May i recomend getting a new intake that has the exit hole that allows you to connect the pipe from the BOV to the intake. (notice the open hole in the BOV)
Old Jul 20, 2006 | 06:55 PM
agallardo's Avatar
Default RE: MBC?
Seems like you have one. Try turning up the boost a little bit and see if it works. Turn it clockwise a little bit. Then test drive it. If it doesnt work, turn it up a little bit more. And then test drive it again. Do it little by little.
Old Jul 20, 2006 | 08:33 PM
2nd g eclipse gst's Avatar
Default RE: MBC?
shebba, i dont have my bov connected to the intake could that be the reason why my boost gauge isnt going past 9 psi and what does it do???
Old Jul 20, 2006 | 08:53 PM
Default RE: MBC?
No it shouldnt be... it will just make your car run a little rich and generally like crap... i guess it could be a possibility and you should change it anyway!!!... but i dont think it will fix your problem... but still get that pipe back on
Old Jul 20, 2006 | 09:06 PM
Default RE: MBC?
i think ima have to agree with you that its prolly my turbo, and to tell you the truth my car really dont have the power that it used to!!!
Old Jul 20, 2006 | 10:43 PM
Default RE: MBC?
venting wont mess up your boost, it really only messes up your idle
Old Jul 21, 2006 | 12:45 AM
Street Surgeon's Avatar
Default RE: MBC?
It will run rich everytime you shift and slightly bog down your car. Everytime you shift and the Type-S pops off, the ECU automatically "thinks" that air is being recirculated into the system, and therefore adds fuel for that air. The problem is that the air isn't in the intake tract like it's supposed to be so the car momentarily runs rich. You may or may not notice it as some cars react differently but it happens.
