Misfire
Old 10-25-2008 | 09:38 PM
eclipseGS98's Avatar
Default Misfire
I need some help guys. My eclipse has been having a misfire. The check engine light flashes and then stays off. Cant remember if thats a type A or B. Also I changed the plugs and when I took the old plugs out, theplug all the way to the right if youre looking at it from the front, is black and all the others look fine. Changing the plugs also didn't help. I was wondering if I could get some input from you guys and let me know what I should check. Thanks!
http://i5.photobucket.com/albums/y19...e/IMG_0090.jpg
Please check out the pic
Old 10-25-2008 | 09:41 PM
Default RE: Misfire
Make sure they are all gapped between 28 and 32. And get new spark plug wires too.
Old 10-25-2008 | 09:51 PM
Default RE: Misfire
Would that be turning the plug black though?
Old 10-25-2008 | 11:58 PM
estraw's Avatar
Default RE: Misfire
if they arent gapped propperly then its not gonna burn all the fuel, causing that cylinder to run rich, and turning your plug black
so.. yes, yes it will
Old 10-26-2008 | 09:39 AM
dsm1990gsx's Avatar
Default RE: Misfire
If a single cylinder is not firing it will turn the plug black b/c its not igniting the fuel.
Old 10-26-2008 | 10:36 PM
Default RE: Misfire
I did a compression test and found that one of the cylinders has less than half the compression as the others. Me and my friend pulled the motor today to open it up to find out whats wrong but of course we dont have bolts long enough to mount it to the motor stand. Also forgot to put oil in the cylinder and doing to compression test to see if its bad rings. Oh well, never hurts to rebuild the motor.
nsmith5785
07-11-2006 12:18 AM
svnlogin
04-15-2006 06:03 PM
maimunatu77
09-09-2004 05:40 AM
maimunatu77
09-09-2004 05:37 AM
Schmyggy
07-07-2004 12:04 PM
Quick Reply: Misfire
