Misfire
Old Dec 24, 2008 | 10:33 PM
eclipseGS98's Avatar
Default Misfire
Tonight I messed around with my car a bit more to see if I could get it to stop misfiring. No luck. I took the injectors out and cleaned them. The motor has also just been rebuilt. The check engine light blinks a few times and stays on, if I remember correctly thats a type a misfire? If you know of any test I can try to find out what is causing the misfire, let me know please. I forgot to mention that its really boggy below 3k rpm then after that it takes off fine unless I floor it. I was thinking clogged injector thats staying open and flooding the cylinder.
Old Dec 25, 2008 | 07:15 PM
estraw's Avatar
Default RE: Misfire
whats the code reading?
Old Dec 25, 2008 | 07:43 PM
Default RE: Misfire
No idea. Haven't hooked the reader up yet.
Old Dec 25, 2008 | 08:06 PM
dsm1990gsx's Avatar
Default RE: Misfire
Get it scanned at autozone and post the code you get.
Old Dec 26, 2008 | 12:58 PM
Default RE: Misfire
The codes coming up are P0304Misfire cylinder #4 and P0455 which is an EVAP leak that has been on forever so I'm not worried about that. If anyone knows more, please fill me in!!
Old Dec 26, 2008 | 03:14 PM
dsm1990gsx's Avatar
Default RE: Misfire
If the #4 injector is stuck open the plug would be fuel fouled and black. Did you pull the plugs and see what they look like? What plug wires do u have?
Old Dec 26, 2008 | 09:58 PM
Default RE: Misfire
One of the plugs did come out black before we tore the motor apart and after. When I cleaned the injectors and put them back in I didn't mark which one came from which cylinder. So I was thinking of pulling all the plugs and replacing what ever ones are black with the clean ones and then whichever of those comes out black is the bad cylinder. Ill take a pic of all plugs too before I swap them around.
Old Dec 26, 2008 | 10:41 PM
Default RE: Misfire
Thats in order from the cylinder one the drive belt side to the cylinder on the tranny side.
According to the book the cylinders fire 1-3-4-2 and if you look at the 3rd one from the left there is some build up on it. The wires are the original wires I believe.
Old Dec 27, 2008 | 07:30 AM
dsm1990gsx's Avatar
Default RE: Misfire
Old Dec 27, 2008 | 07:31 AM
dsm1990gsx's Avatar
Default RE: Misfire
If the wires are original then change them.
