mitsubishi eclipse RS starting issue
Old Feb 17, 2014 | 06:01 PM
Dualsantana's Avatar
Post mitsubishi eclipse RS starting issue
Hello Everyone!
My car is having a weird issue when it's cold. When the engine is cold my car will start kind of ruff. When its warming up I can heard the idle going up and down a couple of times. Sometimes when the engine is cold and I drive for just 2 minutes and turn off the engine, my engine won't turn back on. It will crank but it won't turn on unless I press the gas. I have already replace the battery, spark plugs and wires, fuel pump, fuel filter, air filter, and all my belts are brand new. I have done some research and I have determined that it could be something with the idle control valve. To me that will make sense since I do sometimes experience 800Rpm at red light . I plan on taking my car to the mechanic this week. I told my mechanic all the symptoms and he said it might be coolant leaking into the engine but to me that does not make sense since my coolant level is good. If anyone knows what it could please let me know.
Car info
1997 Mitsubishi eclipse rs non turbo.
miles: 170,,,,,,,,
Old Feb 21, 2014 | 11:01 PM
Update,
The head gasket is going to be replace because of coolant going into the engine. My mechanic show me under the engine of the oil that the head gasket is also leaking. However, I am confuse because I never knew that head gasket could leak oil. Is this possible in 1997 Mitsubishi eclipse 2.0 non turbo?
Old May 11, 2014 | 05:02 PM
uncfraz's Avatar
I have had a similar starting issue with my car. idk if you had your check engine light checked but mine was throwing a camshaft positioning sensor going bad. that fixed my problem. don't know if it will be that easy for you but worth a shot. its about a $60 part at the stores. and yes it is possible to leak from there. its a hassle to fix trying to get the head off
Dualsantana
Feb 17, 2014 05:47 PM
WxDarklingxW
Nov 16, 2012 07:57 AM
link
Oct 30, 2012 11:37 PM
ryguy2503
Mar 4, 2012 06:49 PM
Camster45
Jun 13, 2011 09:43 AM
