modding
Old Apr 7, 2009 | 08:02 PM
c577's Avatar
Default modding
alright i just finally put my parts from my old wrecked car onto my new car, e3 16g, 255lph fuel pump, boost guage, home made mbc. will be getting exhaust in a week, other than the above mods, the car is all stock except the bov. whats next??? and what can i set boost to safely on the above mods including exhaust?
edit: also what is the difference between a 255lph and a 255lph high pressure? i have the high pressure pump because i had braided lines on last car and this car i dont, im not going to break them am i ? lol
Old Apr 7, 2009 | 08:30 PM
dsm1990gsx's Avatar
Your gonna need am apfr to control the 255 pump. 14-15 psi should be fine.
Old Apr 7, 2009 | 09:03 PM
c577's Avatar
what would i set the fpr to??? and i plan to get injectors soon after the exhaust and after getting those ill be gettin a tune and probably a fmic and then the car will be finished. so for that setup, what size injectors would you all recommend, or is there anything else that should be done to the car before labeling it a success?
Old Apr 8, 2009 | 08:29 AM
id say 650cc injectors, and for the fuel pump checkout www.vfaq.com it has a writeup in there on how to set it.
Also how do you plan on tuning it?
Old Apr 9, 2009 | 03:41 PM
c577's Avatar
my friend has a dsmlink and im pretty positive my ecu is an eprom and if not ill just buy one no biggie, arent expensive
Old Apr 9, 2009 | 03:44 PM
c577's Avatar
vfaq said
Tip #1 - be prepared to cuss like a WWII trench soldier.
* Why?
o Because the top fuel fitting isn't usable, unless you want to risk breaking the pump assembly
o Because you'll have to use the bottom fuel fitting, which requires jacking up the car for decent access
about the 255 fuel pump, i didnt do anything like that for my talon do i really need to change any fuel fittings???
Old Apr 10, 2009 | 07:32 AM
i was talking about this writeup
http://www.vfaq.com/mods/FPR.html
because you were asking how to set the FPR
Old Apr 13, 2009 | 09:33 PM
c577's Avatar
lol looks pretty complicated but ill look into it more once i get one, but until then.
i got my 16g on and the mbc, other than that the only thing not stock is the bov. so, should i put the 255 on now? or wait till i get the fpr and exhaust??? cuz i already have the 255
Old Apr 14, 2009 | 06:40 AM
your gonna have to wait
Old Apr 14, 2009 | 04:02 PM
dsm1990gsx's Avatar
Get the afpr then put the 255 in, the exhaust you can put on now.
dirtwagon
Jul 13, 2006 09:22 PM
99clipsgst
May 27, 2006 05:11 PM
GST
Feb 15, 2006 09:11 PM
DJ SlipStream
Oct 12, 2005 06:49 PM
boyblue
Dec 16, 2004 07:00 PM
