MSD Ignition Question
If i get the MSD 4 tower coil pn 8229 should i get the MSD ignition control 2 which is part number 6211 for added performance?
or does the ignition control really help that much, and if it does, are they hard to intstall?
RE: MSD Ignition Question
Is this for an eclipse? the stock ignition system is actually quite good and just some better plug wires are all you need for 10 second quarter miles. I dont know if this is going to be money well spent.
Okay that helps but i was upgrading and adding mods to, so i was wanting to upgrade the ingition set up 2, and i didnt know if i had to have the dis 2, or if i could just use the tower, here is the list of mods in going to add along with things im going to change out Also what is better a K&N (FIPK) or a cold air intake Kit.
Greddy Electronic Boost Controller PRofec B Spec II
Aexi intercooler pipe Kit With Intercooler
Greddy (BOV)
Greddy Turbo Timer
Greddy Grex Front Strut Tower Bar
Greddy Evo2 exhaust
Greddy Radiator Hoses
8.5mm Magnacor KV85 plug wires
K&N (FIPK)
MSD Blaster Coil Pack
Denso Iridium spark plugs
Ecsort 8500 radar detector
New Battery
New Waste gate Spring
Greddy (BOV)
Greddy Turbo Timer
Greddy Evo2 exhaust
K&N (FIPK)
New Battery
ORIGINAL: get435
i have the MSD 4 tower coil pack and 8.5 super conductor wires and it seamed to make a slight differance with the higher voltage delivery to the plug.
