my oil pressure and gas gauges...not working
Old Jan 4, 2007 | 10:39 PM
50ul }{4ck3r's Avatar
Default my oil pressure and gas gauges...not working
any one know what could be wrong with my oil pressure and gas gauges...not working
Old Jan 5, 2007 | 08:48 AM
racerx55's Avatar
Default RE: my oil pressure and gas gauges...not working
my oil guage doesnt work because the typical POS sending unit went badthat nobody sells.
check the wire to make sure its connected down near the oil filter.
Old Jan 5, 2007 | 02:34 PM
Simss's Avatar
my oil presure gauge also went out
Old Jan 5, 2007 | 03:49 PM
there is a plug that is not pluged in to nothing....and cant find out were it goes
Old Jan 5, 2007 | 06:54 PM
93eclipsegsx's Avatar
where is the plug your talking about?
Old Jan 5, 2007 | 09:37 PM
its in the front...look at the pic
[IMG]local://upfiles/10926/FFA0E374C16F4D4FB8005E434B00FED8.jpg[/IMG]
Old Jan 6, 2007 | 05:40 AM
silvercoupe97's Avatar
That looks like foglamp plugs. If you pan to the left, just past the alternator, you will see where the oil pressure sender is located. It's on the oil filter bracket and it faces towards the firewall and points upwards. Check there to see if it's plugged in.
Old Jan 6, 2007 | 04:15 PM
any body have a pic of it.....of the plug
Old Jan 6, 2007 | 05:02 PM
echostats's Avatar
ORIGINAL: 50ul }{4ck3r
Yea, that's for your foglights.
Old Jan 7, 2007 | 06:33 AM
racerx55's Avatar
Heres a pic of the oil sending unit on my old blown up motor. the can thing at the lower left, there should be a green single wire to it.
yours might be different, mines a 1gName:  DSC01609.jpg
