my peice of s***
Old Aug 22, 2007 | 10:06 PM
  #41
itsme71190's Avatar
Default RE: my peice of s***
Im just not ganna do it again.
Old Aug 22, 2007 | 11:00 PM
  #42
2nd g eclipse gst's Avatar
alright dude, do this and i promise this will work!!! take all ur plugs out and put a dry rag on a long stick of some type and stick it down into each one and the water will come out of there, it happend to me so just try and if it works im ur hero if it doesnt well i tryed lol but do it
Old Aug 23, 2007 | 11:13 AM
  #43
itsme71190's Avatar
o they r dry. i vacumd them out. tryd to start it. nothin happend. then put a lil gas to get the spark.. nothing
Old Aug 23, 2007 | 06:29 PM
  #44
itsme71190's Avatar
been thinking. could it b my timing??
Old Aug 23, 2007 | 08:37 PM
  #45
Catch22!'s Avatar
There is nothing wrong with your timing, your belts or anything else mechanical. You got it wet. First rule of automotives is look for the obvious. Nothing you have said would indicate you messed with any mechanical part. Get a can of Wire Dry and spray every electrical connection under the hood with it.
If you have not fried the ECU, it should start. If it does not, good luck.
Old Aug 23, 2007 | 11:32 PM
  #46
itsme71190's Avatar
then should i also try a new ecu?
Old Aug 24, 2007 | 06:21 PM
  #47
itsme71190's Avatar
found out the problem. my damn timing belt is snaped
Old Aug 24, 2007 | 07:52 PM
  #48
ORIGINAL: Sebba
Either that or your timing belt just slipped
I called it : )
Old Aug 25, 2007 | 12:25 AM
  #49
itsme71190's Avatar
i thought it was the belt the whole time. n when u said it gave me me confidence. well sence i gatta replace that. im ganna rebuild the head.
two3000gts
Apr 5, 2009 12:00 PM
StatixNWH
Sep 30, 2006 06:22 AM
StatixNWH
Sep 11, 2006 03:44 AM
suntaker
Jun 20, 2005 11:57 AM
