Is it my test pipe?
Old Aug 15, 2010 | 01:06 AM
3000gt16's Avatar
Default Is it my test pipe?
Okay, so my brother did the dollar bill test with my exhaust. The bill slightly sucked into the exhaust, meaning thee was a vacuum effect going the wrong way. He concluded this to be a bad exhaust valve. I went catless on my rs, replacing the catalytic converter with a test pipe. I read a while back that going catless on a nonturbo vehicle will dramatically throw off the backpressure, causing rough idle, backfires and even flames when shifting at high rpms.
Could the test pipe, which is reportedly known to screw up backpressure, perhaps be the culprit for the conclusion of the dollar bill test?
Old Aug 16, 2010 | 08:11 PM
is the car not running right? A NA car needs some backpressure and alittle is not a problem. It will also increase from things like removing the cat so its not really anything to be worried about, unless you have other things going wrong with the car. It will make it run allitle rich sometimes (causing backfiring and flames in extreme cases).
Old Aug 16, 2010 | 11:21 PM
3000gt16's Avatar
Well it idles like its got the flu or something. Maybe the running video will help diagnose?
http://www.youtube.com/watch?v=ULF9ae4ji5s
Just rolling forward and back in the driveway, showin it moves, but you can hear it idle.
bestwiseguy
May 2, 2007 08:13 PM
fobrob02
Aug 7, 2006 01:35 AM
speedrac3r_de3
Jan 29, 2006 03:24 AM
nate5023
Apr 18, 2005 12:48 AM
v12_killer
May 2, 2004 01:07 PM
