Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
High Flow Cat and Test Pipe
Old Jan 20, 2005 | 11:18 PM
nate5023's Avatar
Default High Flow Cat and Test Pipe
I think that I might get a high flow cat for my car because I'm going to buy exhaust sometime this week and I'm going to be buying a dp from roadrace engineering with a high flow cat. I have heard that the high flow cats will collect a lot of carbon, so I am wondering if that is true and if it is can you clean it? I am also wondering how the test pipe will sound, I heard its a lot louder.
Old Jan 21, 2005 | 09:53 AM
customizedrides's Avatar
Default RE: High Flow Cat and Test Pipe
The carbon build up is all in your tuning man. If your not getting enough fire in your cylinders to burn up alll the mixture then you will deffinatly have some build up. There really isn't anyway to clean that out. Just make sure that you air/fuel ratio is set to specs and you hae some good spark plugs and all cylinders are firing in the right order and on time. Good luck it should sound SIC!
Old Jan 23, 2005 | 04:18 AM
DSMTalonAWD51's Avatar
What kind of exhaust? hopefully apex n1 because i believe that is the only exhaust that is a direct bolton for roadrace's downpipe and highflow cat. And yea I dont think that the buildup can really be cleaned just make sure your engine is running in tip top shape new plugs etc. As for the sound of the test pipe, yes it is loud. Personally I don't think its worth it to drive around with a testpipe. It would be nice to put on for an extra 10hp for the track, but it sounds like crap an you'll get sick of the sound, not to mention it smells. Also, if cops are a problem where you are from thats a hefty fine for getting caught with no cat. In cali i think its like $2000
Old Jan 23, 2005 | 04:25 AM
Prophet's Avatar
ORIGINAL: DSMTalonAWD51
And a nice trip to the ref to be labeled a Gross Polluter.
Old Jan 23, 2005 | 05:15 PM
vertstanggt's Avatar
I have an off-road Xpipe on my mustang, on that it sounds amazing but I don't know if I'd like that sound on this as much. Go with the cat, especially since you're in cali.
Old Feb 21, 2005 | 03:21 AM
wicked_outlander's Avatar
its gonna get dirty somehow.....give em' a try, its worth it!!
Old Feb 22, 2005 | 10:06 PM
96awd's Avatar
i have a test pipe and 2.5 exhaust. apexi n1 it sounds good.
Old Apr 15, 2005 | 04:53 PM
A TEST PIPE??
Old Apr 16, 2005 | 01:26 PM
test pipe: replaces your cat as a strait pipe: better flow: louder: morepollution: illegal
anyone like my flow diagram?
Old Apr 18, 2005 | 12:48 AM
lolz...awwweeee.....
motu1983
Sep 13, 2007 10:50 AM
fobrob02
Aug 7, 2006 01:35 AM
Jeff822
Jan 17, 2006 02:51 PM
eclipse7rdshop
May 27, 2005 09:29 PM
jsaculles
Jun 13, 2004 10:33 PM
