Is my transmission dead?
So the other day my 96 gsx was making a sound that was similar to the sound of my gears grinding, but it was making this sound while I was just driving around.
So my friend said it was my tranny, so we decided to change the gear oil. I put in that vavoline 75w90 synthetic that kragen sells. I drove it around right after I changed it and it was great. Then about an hour later I drove it to my parents house and it started to smelling like burning gear oil and the transmission started to make this whining sound while I was driving. I get off the freeway and I can barely get into my gears. I get to my parents house and find out that my that my transaxle was leaking and so I drained that again and refilled it, and put more of the vavoline stuff in. and it didn't leak again. but when I was driving home it had the same problem.
So is my tranny shot or what? any help would be appreciated.
Maybe I should have mentioned this before, but before I changed the transaxle fluid the second time, this caused my speedometer to go out, also my clutch fork is going/gone. I don't know if any of that could be related.
Ok, So I just took it for a short drive. It wasn't hard to get into gears, but it was grinding pretty horribly, and it it was grinding while I drove but it wasn't a constant hard grind. Also when the clutch was out there was another very quite grind/ticking sound that went away when I pushed the clutch in.
