Is my transmission dead?
Old Jul 4, 2010 | 11:24 AM
branjam13's Avatar
Default Is my transmission dead?
So the other day my 96 gsx was making a sound that was similar to the sound of my gears grinding, but it was making this sound while I was just driving around.
So my friend said it was my tranny, so we decided to change the gear oil. I put in that vavoline 75w90 synthetic that kragen sells. I drove it around right after I changed it and it was great. Then about an hour later I drove it to my parents house and it started to smelling like burning gear oil and the transmission started to make this whining sound while I was driving. I get off the freeway and I can barely get into my gears. I get to my parents house and find out that my that my transaxle was leaking and so I drained that again and refilled it, and put more of the vavoline stuff in. and it didn't leak again. but when I was driving home it had the same problem.
So is my tranny shot or what? any help would be appreciated.
Old Jul 4, 2010 | 11:49 AM
dsm1990gsx's Avatar
Where was it leaking from?
Old Jul 4, 2010 | 12:00 PM
branjam13's Avatar
It was leaking from the transaxle, so I bought a new seal for it and as far as I can tell its not leaking anymore.
Old Jul 4, 2010 | 12:13 PM
dsm1990gsx's Avatar
Did it make the noise again or was it just hard to shift?
Old Jul 4, 2010 | 12:18 PM
branjam13's Avatar
It was still the noise, and it was still hard to shift. Did I use the wrong gear oil? That is the only thing I can think of at the moment.
Old Jul 4, 2010 | 12:24 PM
branjam13's Avatar
Maybe I should have mentioned this before, but before I changed the transaxle fluid the second time, this caused my speedometer to go out, also my clutch fork is going/gone. I don't know if any of that could be related.
Old Jul 4, 2010 | 01:47 PM
dsm1990gsx's Avatar
Well if the noise comes back its probably a bearing inside the trans going bad. Does the noise change w/ the clutch pedal in or out?
Old Jul 4, 2010 | 02:21 PM
branjam13's Avatar
I believe it went away when I pushed the clutch in. It has been a week since I drove it, I will drive it again later today and make sure. Then ill let you know.
Old Jul 6, 2010 | 07:48 PM
branjam13's Avatar
Ok, So I just took it for a short drive. It wasn't hard to get into gears, but it was grinding pretty horribly, and it it was grinding while I drove but it wasn't a constant hard grind. Also when the clutch was out there was another very quite grind/ticking sound that went away when I pushed the clutch in.
Old Jul 7, 2010 | 07:21 PM
dsm1990gsx's Avatar
It might be time to pull the trans out and see if the tob is wasted.
