Need Help
Old Sep 18, 2007 | 12:29 PM
Pribs's Avatar
Default Need Help
Welcome to my hell I just installed my Big 16g hooked everything back up literally on the last bolt on the oil return and it snaps.(on the oil pan)I would have been done but know I am leaking oil out of it and have no way of getting the sucker out. Does any1 have any idea how I can seal this thing? I know it is n ot pressurized so a sealant could work I'm thinking. Any ideas out ther?
Old Sep 18, 2007 | 12:39 PM
eclipseGS98's Avatar
Default RE: Need Help
You can get it out if you spend a fw bucks. Drill a hole through the center of the bolt, geta revered tap and crresponding screws and screw a screw into it
Old Sep 18, 2007 | 12:41 PM
id say you need to just retap it. It shouldnt take too long. Is it the bolt at the oil pan
Old Sep 18, 2007 | 12:48 PM
Pribs's Avatar
yeah it is the bolt in the oil pan. BTW I have no idea what retapping is. and the bolt head snapped off so there is nothing for me to grab onto
Old Sep 18, 2007 | 02:44 PM
Simss's Avatar
I would say if you dont knowwhat you are doing take it to a shop they will charge you like 60 dollars probably. Ive heard and seen first hand way to many stories of the drill bit braking in the bolt and then you being screwed
Old Sep 18, 2007 | 03:43 PM
Get a removal tool. You buy the bit, then drill a hole into the snapped screw... and hammer the bit you bought into the hole (the hole should be the size of the tip) then attach a drill to the bit, put it in reverse and out it should come. I removed 6 stripped bolts a few days ago with this method.
Old Sep 18, 2007 | 04:33 PM
Pribs's Avatar
thx sebba seems easy enough
Old Sep 18, 2007 | 04:38 PM
Cordless drills DO NOT have enough torque to do this. Just a note.
Make sure you hammer it in the hole good.. it has to be snug and not moving
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
