Need Help!! 420a Cam Timing Marks!!!
Old Feb 21, 2007 | 10:41 AM
RCJr9186's Avatar
Default RE: Need Help!! 420a Cam Timing Marks!!!
pretty sure i tried to tell you that was the problem... hmm
Old Feb 22, 2007 | 11:32 PM
jallen28144's Avatar
No, jackass...you didnt. I had to figure it out on my own, you said "half a tooth" the damn intake cam was 180 degrees off....do you know what 180 degrees is?... That is one half of a revolution, more like 30 or 40 teeth, or to be more precise, one half of the number of total teeth on the cam, to make it elementary for you. All you did was tell me what I already knew. Thanks for nothing, and way to be a smartass...do you feel like a big boy now?
Old Feb 23, 2007 | 12:30 AM
RCJr9186's Avatar
the propper way to align the timing marks up is to have them pointing directly towards eachother, not one up one down or opposite or anything like that
i'm pretty sure that is exactly what i was trying to tell you. get your neon motor panties out of a waud!
Old Feb 23, 2007 | 12:45 AM
First, I think you mean "wad", not waud (whatever the hell that is.) Second, my cam gears have two marks each, directly across from each other. I suppose so you can make sure they are horizontal with the head, but I don't know. Third, if you go back and read all the posts, that is why I was asking about the dowel pins that hold the cam gears on to the cams, not the timing marks on the cams themselves. And, last but not least...it seems alot of your posts that I have read on this forum make you sound like a total smartass.
I know, I know...I am a smartass too, but only when called for.
And now my friend, I have told you the problem...hmm
Old Feb 23, 2007 | 10:16 AM
RCJr9186's Avatar
i wasn't being a smart *** at all in this thread, this is the first time i have ever dealt w/ you so i wanted to give up front advice. from what i read in your posts it sounded like the timing marks WERE either 90 or 180 off. i was trying to straighten you out. i'm only a smart *** when 1 the question is stupid or 2 i know the person i'm talking to.
Old Feb 23, 2007 | 11:54 AM
Joel_CA's Avatar
If you took the timing belt apart a #1 TDC where the timing marks point at one another- you wouldn't have had anything to worry about in the 1st place. Even if the cam moved due to valve spring tension- the marks on the sprocket will indicate which way it moved.
J
Old Sep 7, 2013 | 12:40 PM
Joe Stanley's Avatar
just joined up so i could tell all of you thank you for the information in this thread. been looking for this precise information for the past 5 months. thank you thank you thank you
sherk
Mar 5, 2013 10:47 AM
Crew Chief
Aug 7, 2007 12:42 PM
bigguy6f4
1st Generation
Jul 9, 2007 05:45 PM
dwdwdw
Dec 11, 2005 10:17 AM
dkling1263
Aug 14, 2005 11:40 AM
