Need help with my 96 eclipse
My car starts just fine, I can drive it until the engine warms up. Once the engine is warm the car sputters and won't accelerate. If I switch the key to accessory, then back to on I can drive for a couple of minuets, then it starts sputtering again and I repeat the process. I have no idea what could be causing this, and any help is very much appreciated!
I have been having a very similar problem with my 97 eclipse. Except when it would start to sputter i would push in the clutch and it would usually coast fine. But as soon as I let the clutch back in it starts sputtering and dies. Changed out the ecu (I had a spare one sitting around) and the plugs and the problem continued. What parts of the ignition system would you check and how would a novice shade-tree mechanic go about doing that?
thomas4g63
Nov 28, 2008 12:52 PM
Richie03
Dec 12, 2005 11:14 PM
