Need help with my 96 eclipse
Old Feb 6, 2014 | 05:03 PM
Skonkel's Avatar
Default Need help with my 96 eclipse
My car starts just fine, I can drive it until the engine warms up. Once the engine is warm the car sputters and won't accelerate. If I switch the key to accessory, then back to on I can drive for a couple of minuets, then it starts sputtering again and I repeat the process. I have no idea what could be causing this, and any help is very much appreciated!
Old Feb 6, 2014 | 11:49 PM
Akzle's Avatar
ignition system. Leads and plugs.
Old Feb 7, 2014 | 09:33 AM
Skonkel's Avatar
Thanks for the tip! I'm going to buy some new plugs and plug wires and put them in.
Old Feb 7, 2014 | 12:04 PM
Akzle's Avatar
err. CHECK the ignition system before just replacing things.
Plugs you can just replace as a matter of course
Old Jul 13, 2014 | 07:25 PM
evrchanging-ecl's Avatar
I have been having a very similar problem with my 97 eclipse. Except when it would start to sputter i would push in the clutch and it would usually coast fine. But as soon as I let the clutch back in it starts sputtering and dies. Changed out the ecu (I had a spare one sitting around) and the plugs and the problem continued. What parts of the ignition system would you check and how would a novice shade-tree mechanic go about doing that?
thomas4g63
Nov 28, 2008 12:52 PM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
