need some advice on intake and some other stuff
Old Apr 5, 2005 | 10:02 PM
1998blackgst 240's Avatar
Default need some advice on intake and some other stuff
Im looking for an intake and looking to spend around 150 , i have a 98 GST, also i just got a set of lowering springs in and i brought them to midas to gte em put on and they told me its gonna cost 400$. but my friend went about 2 weeks ago and got his on for about 170 at the same place but he has a 97 integra gsr, i dont know if its just the car or is this guys trying to rip me off im going back this weekend to see what he says but anyone know how muhc it should cost?
Old Apr 6, 2005 | 01:09 AM
badass91hatch's Avatar
Default RE: need some advice on intake and some other stuff
400 to install springs? bad move it shouldnt be more than 150 to do that, anymore its a ripoff
Old Apr 6, 2005 | 03:30 PM
spydernoob's Avatar
lowering springs wont help the handling of the car, work on the sway bars and new axles, but lowering looks cool, but dont spend 500 to make your car cool, **** that it looks cool anyways...
Old Apr 6, 2005 | 03:51 PM
DSMTalonAWD51's Avatar
ill install them for $50 all you need is a spring compressor and its very easy. if they said 400 maybe they assumed you need a camber kit, how low are they? 1.3 should be okay without one. but yea if you care at all about handling get shocks over springs. intake: all you need is a filter an adapter : $50 or $90 if you want k&n. build a custom cold air box out of sheet metal/insulation and it will give you as much power as an intake will, especially if u have no front mount.
Old Apr 7, 2005 | 09:36 PM
vertstanggt's Avatar
Shocks will give you a better improvement then springs but springs aren't useless alone. Most springs do more then lower your car, they are also stiffer at least and the ones that are worth buying for most applications are proggresive so you will get a decent ride most of the time but when you corner and the spring starts to compress the rate gets higher. These are of course the milder of springs, I'm not talking about a 3" drop, that's an asthetic thing.
Old Apr 8, 2005 | 04:42 AM
Sanguinius's Avatar
$50 to install springs??? Where you at again? As soon as mine is running and I have the $ for springs I'm comin by!!! You do shocks that cheap too??? (Sorry I HATE playin w the suspension would MUCH rather do a head gasket job thann play w the springs and shocks)
Old Apr 9, 2005 | 06:45 AM
im in socal.
springs do almost nothing for DSM's. lowering our car does not help handling much at all, and if you pair aftermarket springs (very stiff) with the stock shocks (very weak) you will have a worse ride and the stock shocks will wear out A LOT faster.
Old Apr 11, 2005 | 09:18 PM
1398spdr's Avatar
yea, if your gonna do the suspension, do the springs, shocks, and sway bars all at the same time, you will def see a significant improvement over the stock setup..... and lowering does help the handling of the car, it lowers the center of gravity makin it harder to induce body roll..........
Old Apr 12, 2005 | 12:56 PM
springs do theoretically help hanlding by lowering the center of gravity but on DSM's it have been shown to be minimal improvement, and without shocks, the handling with aftermarket springs will be worse and more unpredictable.
DSMCrazy
Aug 1, 2010 03:21 PM
nick_200321
Oct 27, 2007 10:20 PM
Klynt96RST
Oct 16, 2006 01:43 AM
MrJayDeeOne
Jun 28, 2006 10:42 PM
2bar tsi
Feb 24, 2006 11:43 PM
