new to dsm world. simple questions.
Old Aug 6, 2007 | 07:32 PM
phish4709's Avatar
Default new to dsm world. simple questions.
hey im leaving the honda scene and getting a dsm. it's a 1998 eclipse gs-t. i just had two simple questions, one is how much boost can you safely run on a stock 4g63 and also what kinda of hp numbers can i expect (whether it's to the wheelsor crank ) from this set up ( the guy has it on the car already) cold air intake, Thermal R&D catback, exhaust dejon tool upper intercooler piping. the car has 84k miles on it and there is no boost controller installed(so he left it at stock boost) which is a good thing. if anyone can answer my questions i'd greatly appriciate it.
Old Aug 6, 2007 | 07:37 PM
jlh077464's Avatar
Default RE: new to dsm world. simple questions.
Wit a boost contoller and guage, with the mods allready stated, you can run 15psi.
Old Aug 6, 2007 | 07:40 PM
phish4709's Avatar
ok cool, do you know what kinda of numbers it'd be puting down becuase i know that stock a gs-t motors is meant to put out 210...
Old Aug 6, 2007 | 07:56 PM
jlh077464's Avatar
You know I would hate to say an exact number. But you most deff. off to a good start, adding 3psi, you will deff. feel the difference. I have an electronic dual stage boost controller with guage if your interested just p.m. me.
Old Aug 6, 2007 | 08:03 PM
tjbiker031's Avatar
stock internals can hold about 350 HP safely...so they say. but honestly i would just build a 6bolt and make it a beast and swap the two engines out....thats just me tho. oh and put a evo316g or 20g turbo on that ****.
Old Aug 6, 2007 | 08:06 PM
jlh077464's Avatar
Why would you swap out a perfectly fine engine?.....Understandable to do this if the engine in the car blows, but untill then...Drive what you got. It only has 84k on it.
Old Aug 6, 2007 | 08:16 PM
phish4709's Avatar
im going to stick witht he 7 bolt till it blows or gets crank walk:-p and those other two turbos listed, will they bolt straight to the stock manifold?
Old Aug 6, 2007 | 08:23 PM
andrew rs's Avatar
Yes the 16g will bolt right up, its in the same housing as the 14b(stock). Not sure about the 20g tho...
Old Aug 6, 2007 | 08:27 PM
tjbiker031's Avatar
oh no by no means. keep your engine till it blows, but in the meanwhile build a 6 bolt and drop it in.
Old Aug 6, 2007 | 11:40 PM
phish4709's Avatar
can anyone else put anymore input in? greatly appriciated...and stilll would like a guestimate on what kinda numbers that eclipse will be putting down with mods i listed:-p
