new to dsm world. simple questions.
One thing to do before you turn the psi up is remove the stock 2G bov and replace it with a 1G (they're inexpensive used) because they'll hold 18psi consistantly. The stock 2G bov will leak even at stock boost.
ORIGINAL: andrew rs
Yes the 16g will bolt right up, its in the same housing as the 14b(stock). Not sure about the 20g tho...
if you get a boost controller and a gauge, turning up the boost by about 3 or 4 psi you should be hitting around 240-260 hp i believe with those mods
yeah thanks for the info everyone...but still does anyone know how much boost the stock motor can run at safely for daily driving? and honestly i dotn know what the stock boost is? 11psi?
i believe stock boost is about 12psi. removing the BC will bump you up to 13-14psi. but you can get a MBC and run 18 on it all day long. any higher than that and you will max out the turbo and begin to knock.
ORIGINAL: RCJr9186
