new to dsm world. simple questions.
Old Aug 6, 2007 | 11:48 PM
50ul }{4ck3r's Avatar
Default RE: new to dsm world. simple questions.
hahaha a 6 bolt is a plus yo the engine oil system i mean
Old Aug 6, 2007 | 11:55 PM
sk8dudety's Avatar
if you get a boost controller and a gauge, turning up the boost by about 3 or 4 psi you should be hitting around 240-260 hp i believe with those mods
Old Aug 7, 2007 | 04:02 AM
silvercoupe97's Avatar
One thing to do before you turn the psi up is remove the stock 2G bov and replace it with a 1G (they're inexpensive used) because they'll hold 18psi consistantly. The stock 2G bov will leak even at stock boost.
Old Aug 7, 2007 | 07:31 AM
ORIGINAL: andrew rs
Yes the 16g will bolt right up, its in the same housing as the 14b(stock). Not sure about the 20g tho...
Ummm the stock turbo is not a 14b its a T25 and you need and install kit to bolt on a 16g but the manifold bolt pattern is the same
NO WAY!!. You wont even be close to that, if your talking at the wheels. They put out 210hp at the "crank" remember. So at the wheels its even less. Like 180 or something like that. So you wont get 50hp from 4 psi
Old Aug 7, 2007 | 10:26 AM
Dusty Eclipse's Avatar
Well I see Jon got to the t25/14b thing before I did... But wasnt there another turbo used on 2Gs also? Im pretty sure it wasnt the 14b, but wasnt there another one?
Old Aug 7, 2007 | 10:27 AM
RCJr9186's Avatar
1g = 14b
2g = t25
Old Aug 7, 2007 | 11:46 AM
phish4709's Avatar
yeah thanks for the info everyone...but still does anyone know how much boost the stock motor can run at safely for daily driving? and honestly i dotn know what the stock boost is? 11psi?
Old Aug 7, 2007 | 12:08 PM
RCJr9186's Avatar
i believe stock boost is about 12psi. removing the BC will bump you up to 13-14psi. but you can get a MBC and run 18 on it all day long. any higher than that and you will max out the turbo and begin to knock.
Old Aug 7, 2007 | 05:06 PM
Natedogg89's Avatar
ORIGINAL: RCJr9186
18psi? Are you sure on stock fuel? I thought 15 was the max you could run on stock fuel
Old Aug 7, 2007 | 05:21 PM
phish4709's Avatar
well are you sure 18psi is safe or are you shortening the life of that motor lol
