New transmission
Old Sep 14, 2007 | 07:22 PM
sk8dudety's Avatar
Default New transmission
Hey I have to get a new tranny with this new gsx... now just to clarify, even though this car has a 6-bolt motor, i still have to get a 2g transmission? and only the flywheel has to be for a 6-bolt? or does the 1g and 2g have the same mounting points on the car?
Old Sep 14, 2007 | 07:53 PM
Default RE: New transmission
Nope.. 1g tranny : )
Old Sep 14, 2007 | 08:34 PM
sk8dudety's Avatar
oh wait, so i can't even use a 2g tranny? aha... so they do have the same mounting points on the car?
Old Sep 14, 2007 | 09:28 PM
Oh **** now im doubting myself.........hmmmmmm disregard that
Old Sep 15, 2007 | 09:01 PM
sk8dudety's Avatar
come on, i know you guys know this.... someone's gotta help a brother out
Old Sep 16, 2007 | 06:52 PM
It depends on what the person did. Im pretty sure that the 2g tranny could fit on a 6 bolt block. But you having a GSX the spline on the t-case is what is important. So you need to find out if you have a 22 or 23. Also i think the mounts are different for the 1g and 2g.
Old Sep 18, 2007 | 08:05 AM
sk8dudety's Avatar
ok, its a 23 spline... apparently they stopped making the 22 spline in 1992 (food for thought)... So john, if i remember correctly, the tranny will bolt up to the 6-bolt block, but will need the 6-bolt flywheel, correct? Someone please correct me if I'm wrong... and all you 6-bolt swappers go ahead and jump in on this since you've done this before...
Old Sep 19, 2007 | 02:48 PM
sk8dudety's Avatar
Hey got my answer. I talked to Jarrod at Buschur Racing... he said that the 7-bolt tranny will bolt up and work with the 6-bolt block, all you need is the new 6-bolt flywheel
Old Sep 19, 2007 | 07:10 PM
Thats what i thought but i wasnt 100% sure that the bolt pattern was then same so i didnt want to say it will. Good to know
Old Sep 24, 2007 | 07:31 PM
TSG59_Steve's Avatar
Just some things to add to that, a lot of people don't know. 1) You CAN'T use a 1g tranny different mount, 2) ALL 4g63 clutches are the same. So you can use the existing one no problem, 3) Make sure you get a 6 bolt AWD flywheel. The AWD flywheel is smaller in diameter, compare them if your removing it yourself. The FWD guys that mess up on that just have ano start problem as the starter won't hit the flywheel, not sure what problems the AWD guys would have if they put a flywheel that's too large for it...
