New Wheels and Tires Help!
Old Feb 23, 2007 | 06:08 AM
Simss's Avatar
Default RE: New Wheels and Tires Help!
I used to have a pair of niche 18x8.5 but i traded them for a pair of stock gst 16's with a set of 225/50's and honestly they handle way better than my 18's ever did. If you go anything higher than 17's you really wont be gaining any performance
Old Feb 23, 2007 | 09:54 AM
silvercoupe97's Avatar
One thing to keep in mind is the overall diameter of the wheel. I found that 215/50/17 is only slightly faster than stock.
Type in the wheels that you are thinking of and the program will tell you how fast or slow the speedo will be.
http://www.1010tires.com/TireSizeCalculator.asp
Plug in your preferred tire size and see. Stock 215/55/16
Here's info on stock specs.. http://www.vfaq.com/mods/macross/2Gfitment.html
...and EVO wheels will bolt on, but it will stick out and if you're lowered, it will rub both the front and rear fenders. I put a set on that my buddy was selling just to try them on and if you can live with stock height you may be able to get away with it. Eclipse/Talon offset is 46mm, EVO offset is 35mm-38mm (I forget which.....Emonz...jump in anytime bud). I have 40mm on my car right now and it's barely flush up front and I'm lowered....about to raise it back up due to Hawaii speed..fu#$in'..bumps.
Anyway, just a heads up fellas.
juggelo66
Nov 21, 2008 11:32 PM
bluballz07
Apr 8, 2007 10:58 AM
DRAGNFLIES
Jan 11, 2007 07:07 PM
e_miller81
May 23, 2006 07:11 AM
mclee45
Sep 6, 2004 03:17 AM
