NEWB HERE
Old Apr 11, 2005 | 11:40 AM
PINK63IMPALA's Avatar
Default NEWB HERE
HELLO NEW TO THE SITE
JUST PICKED UP A ECLIPSE FROM SOME HORSE TRADING, BUT HAS A BAD ENGINE.IT HAS A MANUFACTURING DATE OF 1988 IN THE DOOR, IM ASSUMING ITS A 89 MODEL.I BELIEVE IT HAS A 4G73 ENGINE. DOES ANYONE KNOW ANYTHING ABOUT THIS ENGIINE? IS IT JUNK OR WHAT? ALSO WHAT ENGINE WILL INTERCHANGE WITH IT AND USE THE SAME TRANNY?ANY HELP IS APPRECIATED.
Old Apr 11, 2005 | 02:37 PM
get435's Avatar
Default RE: NEWB HERE
the motor is a 4g63. any model of eclipse 89-94 depending on parts should swap fine. what modle is it GSX GS-T GS RS?
Old Apr 11, 2005 | 02:51 PM
THANKS FOR THE INFO ARE YOU SURE ITS A 63?I WORK AT A MACHINE SHOP AND IT LOOKS DIFFERENT FROM A 63.GUESS ILL FIND OUT WHEN I PULL IT. MY PARTS CATALOGE OFFERS IT IN A 4G37? MODEL ENGINE ALSO.WILL A 4G63 OR 4G64 ENGINE BOLT TO THIS TRANNY? I NEED SOME INFO ON THE ELECTRONICS SWAP ALSO IF I GO WITH A DIFFERENT ENGINE.JUST A NEWB TO THE MITS. LINEUP!
Old Apr 11, 2005 | 02:52 PM
ILL CHECK TONIGHT TO SEE WHAT MODEL IT IS
Old Apr 11, 2005 | 10:40 PM
Sanguinius's Avatar
All the 4G63 swaps should electronically not really require much unless you plan on swapping a nonturbo for a turbo or vice versa.
Old Apr 11, 2005 | 10:57 PM
thanks the model is a "gs" if that helps . is there any performance parts available for this?thinking about just rebuilding the engine and selling it.these cars worth anything?
Old Apr 12, 2005 | 02:40 AM
Sanguinius's Avatar
The 4G63 is one of the easier built engines. Especially the 6 bolt block (Which is what you'll have the 7 bolt was '95 and up) there are MANY part available for it out there and it's a rather easy block to work on.
Old Apr 12, 2005 | 12:37 PM
DSMTalonAWD51's Avatar
7bolts started in 92 april
Old Apr 13, 2005 | 01:09 AM
Sanguinius's Avatar
I thought the 7bolt was started in '95 my bad all the info I've been reading on the 2 engines (I'm still not exactly sure on the differences in the 2 other than the alignment pin for the flywheel) I don't remember where I read about the '95 thing I believe it was mentioned in the article psoted in another thread about turbo charging the 4G63
Old Apr 26, 2005 | 02:13 PM
OK , SO I PULLED THE ENGINE AND TORE IT DOWN ,COME TO FIND A WHOLE IN NUMBER ONE PISTON.THIS ENGINE IS A 4G37 CASTING ON IT. ANY ONE KNOW ANY PROS/CONS ON THIS ENGINE.
DMG1287
Jul 5, 2007 05:36 PM
GSXtype
Mar 23, 2007 12:17 PM
ADR2g
Aug 2, 2006 11:21 PM
Huh?
Jan 31, 2006 01:13 PM
seizure
Oct 29, 2003 03:59 PM
