next step on GSX
Old Apr 14, 2006 | 05:28 PM
  #21
Default RE: next step on GSX
ORIGINAL: Sebba
They are right. Change your intake mani just so you can get that extra bit air flow. You will also need fuel mods like injectors and fuel pump. What pressure plate do you have?
Now there is alot of theorys about the crank walk stuff. From everything i have read and entering common sence and logic i have come up with the following: The 6 bolt is a very good strong engine with a good crank. The reason why the crank is better is because it went through a chemical hardening process. The 7 bolt is a better design and of better build quality. However good old mitsu didnt do the same chemical process for the crank. Do not bolt on a 6 bolt bottom end onto your engine. Your engine was built for the 7 bolt crank keep it that way! Good performance shops will offer a 7 bolt chemically hardened crank to eliminate the crank walk problem. This is what i recomend. Not to mention aftermarket pressure plates will speed up crank walk and sitting on the clutch at red lights will speed it up too.
Correct me if im wrong....
What?? dont buy an intake manifold that is very unnessesary at this point. As for the 6 bolt 7 bolt the problem is with the oiling system of the 7 bolt block not the crank. the crank is fine but the oiling in the 7 bolt id poor and has some pressure issues
Old Apr 14, 2006 | 08:52 PM
  #22
Agreed, the oil squirters do get cloged easy and that was a good theory. However, can you explain to me why when you have a nitrided crank that you dont get crank walk anymore?
Old Apr 14, 2006 | 09:18 PM
  #23
ORIGINAL: Sebba
any 7 bolt even after any rebuilds can still walk the crank. I have herd of people walking and then rebuilding useing full internals and have the problem a 2nd time re accur. I hear alot about oil pressure at idle with the clutch pressed cause your applying pressure on the crank at that time as well. I m no pro at the 7 bolt because I have never owned one but there is a sticky I made up above this section called alternate swaps for the 2G GST and GSX that has a good link for crank walk in it
Old Apr 15, 2006 | 11:32 AM
  #24
To some extent you are right. The oil pressure is low at idle causing metal on metal contact with the crank. However this is not the cause of crank walk. If the crank was not soft as swiss cheese it wouldnt happen to begin with. I know for a fact that all the 7 bolt cranks that have been nitrided have never gotten crank walk. Crank walk is caused by the crank because its soft. Once it has been nitrided its alot harder. You did not answer my question. Can you explain why none of the nitrided cranks have gotten crank walk?
Old Apr 15, 2006 | 11:33 AM
  #25
BACK ON TOPIC
I say if you want to be running all that extra power with a really good pressure plate upgrade your crank.
Old Apr 15, 2006 | 05:52 PM
  #26
ORIGINAL: Sebba
Im telling you I have seen 2Gs with 7bolts built up still walk. its nothing with the low pressure at idle but when you are putting pressure on the crank with the clutch that cause a problem. Othe wise why the hell wouldnt guys just upgrade the crank and internals and call it a day because that is easier than swaooing in a 6 bolt and then building a 6 bolt bottom end. It makes no sence to me to drop a 6 bolt in if you can cure the problem.
I think some crankwalk victems need to clear up because I am not sure but it just seems a little far fetched other than the crank and oil jounals
Old Apr 16, 2006 | 12:05 PM
  #27
I know its the pressure from the clutch that does it. Because of the crank being soft! Nitrided the crank and you eliminate the problem.
Built up 7bolts will walk if they have the stock crank. The reason why so many people dont do it is because they are advised just to go with the 6bolt.
I have not heard of a nitrided crank gettin crank walk yet.
Old Apr 16, 2006 | 04:39 PM
  #28
ORIGINAL: Sebba
ok so I give you a mission then. round up all you can on crank walk and lets make a sticky. because I still am not sure about it. If you build a bottom end and use the stock crank again on a 7 bolt that is retarded since you have it out to begin with.
so lets make a good write up for a sticky, if you want to that is I would like a crank walk specific thread up op pinned
Old Apr 17, 2006 | 11:25 AM
  #29
You use a nitrided stock crank! lol You either get it nitrided or you buy one from a good shop that sells them. The best information i have ever come across was on the tampa bay DSM website.
Old Apr 17, 2006 | 11:30 AM
  #30
RCJr9186's Avatar
aight Sebba, if you think that an upgraded crank or "nitrated" crank would completely eliminate crank walk where can i get a suitable crank or what kind of place would "nitrate" my crank for me?
