NGK IRIDIUM any good?
RE: NGK IRIDIUM any good?
ORIGINAL: Nubiebubie_GSX
The ngk bpr6es or 7es work well with the turbo 2nd gen depending on ur mod. Also need to gap them correctly. I had the irridum style and wasn't that great so i switch to those.
The NGK 6ES and 7ES is what every DSM'er will tell you to use. They are tried and true and it makes no sense in trying to reinvent this old horse.
If your ignition is something you're worried about...no need to worry, the ignition system works. The next best thing is a COP (coil over plug). That's overkill though, unless you're making big power and need to have a more complete burn so that you're not running rich or blowing out the fire.
What Sebba stated pretty much sums up the general consensus of the DSM community about the plugs.
If you're still not convinced...try them out. Unless, you notice a huge improvement, don't worry about getting back to us though, unless you've got before and after on a dyno
Oh yeah, you won't be able to "feel" the plugs ignition. You'll only be able to see the numbers on a dyno...yeah, even a butt dyno won't be able to tell. Log it, then you'll be able to tell.
I get mine online. $10 for 4 is the norm. I can never find them in stock at the local parts stores here. I use the 7ES btw, since I'm doing more than stock power, so I went one step colder.
ORIGINAL: silvercoupe97
i actually bought mine from our vendor here. www.sparkplugs.comthey were actually pretty good service
