NGK IRIDIUM any good?
Old Feb 12, 2007 | 03:15 AM
jerusry's Avatar
Default RE: NGK IRIDIUM any good?
okay, well what plugs do you run?? denso iridiums??? just wondering cuz maybe i will try them to see if i like them!!
Old Feb 12, 2007 | 04:09 AM
silvercoupe97's Avatar
ORIGINAL: Nubiebubie_GSX
The ngk bpr6es or 7es work well with the turbo 2nd gen depending on ur mod. Also need to gap them correctly. I had the irridum style and wasn't that great so i switch to those.
I'd say 90% of DSM'ers use NGK BPR6ES and BPR7ES (one step colder than the 6ES). The other 10% use others because they don't know any better
The NGK 6ES and 7ES is what every DSM'er will tell you to use. They are tried and true and it makes no sense in trying to reinvent this old horse.
If your ignition is something you're worried about...no need to worry, the ignition system works. The next best thing is a COP (coil over plug). That's overkill though, unless you're making big power and need to have a more complete burn so that you're not running rich or blowing out the fire.
What Sebba stated pretty much sums up the general consensus of the DSM community about the plugs.
If you're still not convinced...try them out. Unless, you notice a huge improvement, don't worry about getting back to us though, unless you've got before and after on a dyno
Oh yeah, you won't be able to "feel" the plugs ignition. You'll only be able to see the numbers on a dyno...yeah, even a butt dyno won't be able to tell. Log it, then you'll be able to tell.
Old Feb 12, 2007 | 04:25 AM
jerusry's Avatar
i will remember this and try out different ones next time. how much do these ngk's cost and where can i purchase them at?
Old Feb 12, 2007 | 07:02 AM
I get mine online. $10 for 4 is the norm. I can never find them in stock at the local parts stores here. I use the 7ES btw, since I'm doing more than stock power, so I went one step colder.
Old Feb 12, 2007 | 09:39 AM
ORIGINAL: silvercoupe97
yea i go the same way. I went a step colder and i like to use the copper plugs. They dont last as long but you get much better spark
Old Feb 12, 2007 | 02:41 PM
jerusry's Avatar
where do you get them at online??
Old Feb 12, 2007 | 04:49 PM
eclipsefanatic's Avatar
So the ngk copper is better than the irdium. What about the ngk wires, are they any good?
Old Feb 12, 2007 | 05:14 PM
i actually bought mine from our vendor here. www.sparkplugs.comthey were actually pretty good service
Old Feb 12, 2007 | 05:33 PM
jerusry's Avatar
i think i am gonna pick some of those up, when i get 20 bucks! hopefully it helps out a little.... seems like the car runs fine, but maybe it will run better/smoother with those
Old Feb 12, 2007 | 06:34 PM
B.e.R.a.T's Avatar
I use BPR7ES one step colder NGK it works fine.
