No check engine light
Old Nov 1, 2004 | 05:09 PM
hrhoward's Avatar
Default No check engine light
Hi. I have a friend who's girlfriends '95 Eclipse will not start. Quick history as I know it; car intermittently sputtered, dies, starts back up repeat. Had the coil replaced, ran for a bit then same. Then I am called. I checked coil primary and secondary ohms. Fine. No signal to coil from PCM. Two relays on firewall, check out ok via batt voltage. No power to crank or cam sensor. No check engine light so I am unable to do the key dance. So is it the PCM?
Sure could use some help. My experience is with '86-'87 turbo Buicks so please don't hold that against me.
Thanks,
H. Howard
Old Nov 1, 2004 | 05:39 PM
1398spdr's Avatar
Default RE: No check engine light
most likely it is the PCM, if there is no signal from the coil and you know the coil is good........
guyjg
Nov 13, 2021 03:27 PM
SpyderGST
Dec 27, 2014 06:50 PM
pgb205
Jun 4, 2009 10:40 PM
c577
Oct 16, 2007 12:03 AM
rkerner
Jul 22, 2005 01:04 PM
