No compression?? 95 gst
Old Jan 24, 2008 | 12:57 PM
pilsenblue's Avatar
Default No compression?? 95 gst
Ok i share and office with a garage a 95 gst just came in . 17yr old kid had it. Looks like the dad is not gonna spend the money to fix it. no sure what the problem is. (maybe bend vaules) so Im think of trying to buy it from him. for a couple hundred. I have a 97 rs. I know it cant be swaped but what would it cost to but a new engine in ?The 95 gst not the rs. I just figure I should save the car instead of letting it get trashed uknow. I got love for the 2g and wanna keep it on the road
Also anyoneknow what the problem might be?the mech said its not showing and codes so?? and he said theres just no compression.??
New engine over fixing this one whick is better??
Old Jan 24, 2008 | 01:53 PM
Dusty Eclipse's Avatar
Default RE: No compression?? 95 gst
Blown head?
Old Jan 24, 2008 | 02:10 PM
dorian7's Avatar
Well it depends on how many miles are on it, if it is 100+ with the original then I would say new engine. You could also do a 6 bolt swap so you never have to worry about crankwalk.
Old Jan 24, 2008 | 03:11 PM
pilsenblue's Avatar
Piston and everything is moving inside. thinking maybe the kid rev'd it too high?
It's got 140.xxx on it.
Old Jan 24, 2008 | 03:46 PM
what are the actual compression #'s on all the cylinders. It would be pretty rare to see absolute zero on all cylinders
Old Jan 24, 2008 | 03:58 PM
Rob's Avatar
Rob
Even if you can get it for under a grand, do it. Drop a 6 bolt in it when you have the extra chedda, the sell teh b1tch and make some money.
Old Jan 24, 2008 | 04:04 PM
Im still saying theres gonna just be a big gaping hole in that head somewhere
Old Jan 24, 2008 | 04:38 PM
estraw's Avatar
the only way its gonna be 0 on all the cylinders is if the timings off or if the valves are bent.
Old Jan 24, 2008 | 06:40 PM
Check the timing first off. That will pretty much tell you.
Are the compression numbers dead zero?
Old Jan 25, 2008 | 11:22 AM
pilsenblue's Avatar
Rockers fell off on the intake side. Think the vaules were bent. anyways the damn kid wants 1500 for it. Not sure its worth it .interior was kinda crappy bent rim. Better off anyways I want a ggx
