no reverse lights and turn signal won't turn off
Old May 22, 2006 | 01:17 AM
dornstar's Avatar
Default no reverse lights and turn signal won't turn off
I need a little help with my 98 Eclipse RS 5 speed. I'm driving from Ohio to Florida tomorrow and earlier today, all my turn signals wouldn't turn off and my reverse lights aren't working. I had to remove the turn signal fuse so that it didn't look like I was driving with my hazards on. I went out and replaced the fuse a little while ago and now my driver side turn signals won't turn off, but the passenger side aren't blinking. I am able to turn my hazards on and off, so I doubt it has anything to due with the problem and the bulbs look good. Anyways, I won't be able to get the car into the shop, so does anyone have an idea what could be causing the problem.
Old May 22, 2006 | 03:28 AM
AznLibra929's Avatar
Default RE: no reverse lights and turn signal won't turn off
is the blinker blinks faster than normal?
Old May 22, 2006 | 11:53 AM
dornstar's Avatar
Yeah, it was blinking faster for the last couply of days and all of a sudden this happened.
Old May 22, 2006 | 03:05 PM
03gteclipse's Avatar
sounds like a possible short in your signals. loose wires perhaps. you try replacing bulbs, or taking off lenses to check wires?
Old May 22, 2006 | 04:26 PM
you have a burned bulb somewhere. you have to check them again. once you replace the burned bulb. then you're good to go
Old May 22, 2006 | 04:58 PM
NubianSithLord's Avatar
You def have a blown/burnt bulb best thing to replace all turn/parking blubs the come to in a pack you shouls be good to go!
ehsanabria
Sep 22, 2022 06:22 PM
athlete1012
Jul 14, 2010 09:06 PM
kshollywood
Jan 14, 2009 06:13 PM
98Montero
Oct 19, 2008 08:43 PM
foutong
Dec 4, 2007 05:44 AM
