Left Turn Signal Won't Stop flasing!
Old Sep 11, 2007 | 09:57 AM
athlete1012's Avatar
Default Left Turn Signal Won't Stop flasing!
Hello Can anyone help me out? I am having trouble with my left turn signal. It was working fine I went to make a left turn and the handle click back to its original positon but the light continues to flash. When I click it to the right signal it doesn't do anything no light at all but the handle clicks. I tried changing the fuse but no luck. It still is flashing only goes off when I turn off the car. The headlight work fine and the hazards are okay as well. DO you know what may be causing this? What would it cost to repair?
Old Jun 10, 2010 | 06:23 PM
rufio651's Avatar
im having the same problem with my 95 galant. ive tried replacing the flasher unit under the steering column and im still having the same problem. any suggestions? anybody?
Chris
Old Jul 14, 2010 | 09:06 PM
michaelross's Avatar
Sounds like the turn signal switch is already defective. Or the blinker fluid might be dirty and/or over filled causing the switch to stay in a stuck open mode.
2000MonteroSport
Aug 7, 2012 04:15 PM
dvir
Jul 26, 2012 09:15 AM
98Montero
Oct 19, 2008 08:43 PM
capecodder
Aug 4, 2007 08:32 PM
dornstar
May 22, 2006 04:58 PM
