no spark
RE: no spark
Ok, this may sound odd, but keep sniffing around for the smell. If it's not the motor's ECU, then it could be some other ECU under the dash or a relay.
The fusible links are those big fuses. Those can handle more power than the rinky dink fuses. They do the same thing as a fuse but are more tolerable to accidents such as arcing, the smaller fuses do the job of individual protection.
RE: no spark
Silvercoupe how do you check these fusible links? Just look down inside them from the top and see if there burnt?? Or is there a certian resistance i should check for on an ohm meter?? This could also be my problem. These things are in TIGHT on my car. I tried to pull one out and it was just not happening.
RE: no spark
ORIGINAL: Scubba.steve
RE: no spark
ORIGINAL: c577
i have checked all fuses and fusible links inside the two fuse boxes and they are all fine also, my friend said it could be an ignition module?
[align=left] [/align]
dozracing
02-16-2004 04:41 AM
