no spark
Old Sep 23, 2008 | 01:04 PM
c577's Avatar
Default RE: no spark
the comp looks and smells good, no burn marks at all
[align=left] [/align]
Old Sep 23, 2008 | 02:50 PM
silvercoupe97's Avatar
Ok, this may sound odd, but keep sniffing around for the smell. If it's not the motor's ECU, then it could be some other ECU under the dash or a relay.
The fusible links are those big fuses. Those can handle more power than the rinky dink fuses. They do the same thing as a fuse but are more tolerable to accidents such as arcing, the smaller fuses do the job of individual protection.
Old Sep 23, 2008 | 03:17 PM
Scubba.steve's Avatar
Silvercoupe how do you check these fusible links? Just look down inside them from the top and see if there burnt?? Or is there a certian resistance i should check for on an ohm meter?? This could also be my problem. These things are in TIGHT on my car. I tried to pull one out and it was just not happening.
Old Sep 23, 2008 | 04:29 PM
dsm1990gsx's Avatar
ORIGINAL: Scubba.steve
You can see of they are not making contact on the top and when you pull them out they should have continuity. The alternator fusible link will be hard to pull out since its bolted down.
Old Sep 23, 2008 | 05:29 PM
Yeah you can see into them. If the fuse is shot then you will see where there is a break in it.
That could also be a cause of this problem. Good job Silver
Old Sep 24, 2008 | 03:21 AM
c577's Avatar
i have checked all fuses and fusible links inside the two fuse boxes and they are all fine also, my friend said it could be an ignition module?
Old Sep 24, 2008 | 06:29 AM
ORIGINAL: c577
There is an ignition transistor located between the intake manifold and fuel rail. It is also really close to the coils. Check the contacts and continuity.
Old Oct 4, 2008 | 09:29 PM
c577's Avatar
almost forgot to repost... broken timing belt 8 bent valves, water pump and all that good ****
vcleynes
Nov 25, 2014 12:59 AM
#1 Stunna
Jun 7, 2007 05:59 PM
lelliott
Feb 25, 2004 11:29 AM
dozracing
Feb 16, 2004 04:41 AM
jesse
Dec 21, 2003 03:43 PM
