OBD code PO441
Old Oct 20, 2006 | 03:53 PM
Ingpark1's Avatar
Default OBD code PO441
My daughter's service engine light came on and the code reads PO441. The local service center that I take the car to could not identify what needed to be redone. They reset the computer but the code came back at the next start. They suggested that I take it to the local dealer, but taking it to that shark is a last resort. Any suggestions? Haven't found much on the net. Thx
Old Oct 21, 2006 | 12:02 AM
98MitsGSX's Avatar
Default RE: OBD code PO441
evaporative emission control system incorrect purge flow...
This may be a blockage of a vapor line, or a stuck VSV, as described in troubleshooting area of Repair Manual
Fuel tank cap incorrectly installed <= Most common
Fuel tank cap cracked or damaged (Toyota part only)
Bad vapor pressure sensor/circuit
Vacuum hose cracked, holed, blocked, damaged or disconnected
Hose or tube cracked, holed, damaged, or loose
Fuel tank/filler neck cracked, holed, or damaged
Not sure if any of this really helps...but it's all I could find
Mitsi Allers
Nov 20, 2013 01:11 PM
Sonny Boy
Jun 30, 2011 04:10 PM
Stryker
Sep 16, 2007 08:36 PM
signtist2004
Oct 26, 2006 10:31 AM
hussain74
Aug 24, 2006 09:34 PM
