Which oil is best for gst?
Old Sep 28, 2005 | 10:28 PM
naka's Avatar
Default Which oil is best for gst?
First of all I want to say hi. I am a new member and I hope to learn a lot, and I want to thank you in advance for all your help.
I drive a mitsubishi eclipse gst 98, and I wanted to get an oil change. I would usually just go to jiffylube and have them deal with it but I decided to take better care of my car by using oil that best suits it. Do any of you know which oil is best for my car? thanks.
Old Sep 29, 2005 | 12:10 AM
slow420a's Avatar
Default RE: Which oil is best for gst?
This is asking what kinda of gas to put in your car... kinda... okay bad example but a really good oil depends on what you wnat to spend. Royal purpule is the ****... but I buy mobil one syntech and I am happy with that. Matter factly my friend put syntech in his gf's 1.8t vw and now you can hear the turbo spool where before with ****ty oil you couldent.
Old Sep 29, 2005 | 12:40 AM
naka's Avatar
mobile one syntech. got it. Maybe my turbo will spool louder than before like your friends vw thanks for the help!
Old Sep 29, 2005 | 01:03 PM
shreff99's Avatar
I'm also doing an oil change on my '99 Eclipse GS-T really soon and am switching to Mobil One fully synthetic from Pennzoil 10w 30...I can't wait too see what kind of change it brings and now I have even higher hopes...Which brand of oil filter is going to work best?
Old Sep 29, 2005 | 01:06 PM
get435's Avatar
if you are changin every 3000 miles just make sure it is 98-99% effective should say on box if you go for ex fram go toughguard or better.
Old Sep 29, 2005 | 03:20 PM
DSMTalonAWD51's Avatar
any oilis going to be fine if you change it enough and dont let it run low.
I like mobil 1 10w-30
Old Sep 29, 2005 | 06:38 PM
get435's Avatar
If there are alot of days that do not get above 100deg but get below 0 quite often than use 5w30 if your area gets above 100 a lot but hardly never below 0 than go 10W30.
Old Sep 29, 2005 | 09:48 PM
naka's Avatar
Thanks a lot for the info guys.
Old Sep 30, 2005 | 02:58 AM
CH69NO's Avatar
isn't it bad for u to switch from regular 10-30w to syntec mobil 1???
Old Sep 30, 2005 | 03:03 AM
ORIGINAL: CH69NO
nope
