only 13psi?
Old May 7, 2006 | 02:00 PM
paintballproam's Avatar
Default only 13psi?
about a week ago i put a boost controller and gauge in my '95 GSX. I turned it all the way up and the highest amount of boost i can get is 13psi. I was trying to get 15psi. Any ideas of why this is happening?
Old May 7, 2006 | 04:20 PM
5Tizzle's Avatar
Default RE: only 13psi?
is it an ebay boost controller?
Old May 7, 2006 | 05:00 PM
93eclipsegsx's Avatar
all the way up? did you screw it in all the way or unscrew it?
Old May 7, 2006 | 07:26 PM
5Tizzle's Avatar
ORIGINAL: 93eclipsegsx
Yeah im gonna guess, either its broken, or you are turning it the wrong way. If you turned it all the way up, you should be getting some serious fuel cut.
Old May 7, 2006 | 11:36 PM
its like a turbo x or something. i ordered it from a local tuner shop. i put it all the way towards +. clockwise
Old May 8, 2006 | 12:02 AM
http://cgi.ebay.com/ebaymotors/Turbo...62657300QQrdZ1
this is what it is.
and sorry i turned counterclockwise
Old May 8, 2006 | 12:38 AM
n2daizo123's Avatar
the factory pressure release valve tends to leak above 14lbs.
Old May 8, 2006 | 12:41 AM
are you talking about the factory boost controller? and you need to turn it clockwise to turn up the boost
Old May 8, 2006 | 01:25 AM
n2daizo123's Avatar
no the blow off valve.
Old May 8, 2006 | 10:57 AM
make sure that you have it hooked up right also. One hose should go to the wastegate and the other to the turbo. If not hooked up correctly and in the right direction it will cause it to not work correctly. Your stock bov can leak but it should cause it to only run 13 psi.
Gregory
Jul 26, 2005 01:36 AM
sportee
Jun 16, 2005 03:46 PM
1998blackgst 240
Apr 28, 2005 04:09 PM
SOMEONEWITHNOSINCE
Aug 18, 2004 06:43 PM
outlancer
Aug 10, 2004 11:31 AM
