Over boosting?
Old Sep 27, 2007 | 10:08 AM
tidus10's Avatar
Default Over boosting?
Is it possible to over boost a car?
My teacher is running his stock turbo on a 96 GSX at 16lbs (holding) but it spikes higher he says it used to be running at 21lbs.
Whats the optimal boost for his car? i would like to prove him wrong :-P
Old Sep 27, 2007 | 10:11 AM
jlh077464's Avatar
Default RE: Over boosting?
That is to much boost for the stock turbo and 21 is just not realistic.
Old Sep 27, 2007 | 10:17 AM
tidus10's Avatar
at 16lbs boost isnt he wasting boost out of his BOV? he has a stock Gen 1 BOV
Old Sep 27, 2007 | 11:24 AM
There are many things that will effect what you can run for boost. On a stock 2g you dont really want to run more than 16psi because of the fuel system. The stock t25 isnt even any good past that anyways. And the 1g bov can hold about 18psi. So you are saying he has it set to be 21psi and then it drops off?
Old Sep 27, 2007 | 12:12 PM
tidus10's Avatar
he said it used to hold 21lbs....he is saying the fuel system is bone stock as well.....
Old Sep 27, 2007 | 04:46 PM
bestwiseguy's Avatar
I gotta call BS. there is no way the stock turbo would be able to push 21 lbs. of boost.
Old Sep 27, 2007 | 06:13 PM
TheAdvocate's Avatar
A friend of mine was running a 14b turbo on his GSX, and when his wastegate was screwed up, it would hit 20-21lbs of boost... That was on a pretty much stock setup.. It would get fuel cut though at about 19.. So unless he has stuff upgraded, he wouldnt be hitting 21lbs safely/or smoothly..
Old Sep 27, 2007 | 07:54 PM
yea if he didnt set the psi to be that then its probably the wastegate. But if he said he was setting it to run 21psi and it actually held that or even never fuel cut, then its BS
jdmcivic1999
Oct 1, 2006 07:18 PM
Gstfat
Sep 16, 2006 04:43 AM
mirageracer23
May 20, 2006 11:25 AM
big_will
Nov 2, 2005 10:06 PM
turbodsmdavid
May 10, 2004 10:17 PM
