overboosting problem?
how do i control the boost on a 98 gst with a internally gated big 16g turbo on it? there is no vaccum line connector coming out of the turbo compressor husing. which means i can't run the hose strait from the actuator to the compressor housing. i really need to fix it... how can i fix it? my car boosts ok at like 1/4-1/2 throttle but over that it doesn't do anything really and it cut out and makes a popping noise... how can i fix this problem? oh, i have the stock bov... and i want to install a mbc to keep the boost down.. but without the compressor husing connector i don't know where to put a mbc! PLEASE HELP!!!
that extra nipple on the compressor of the stock turbo is for the bcs. the 16g requires an aftermarket boost controller so go get one. one end will go to the bov vacuum line and the other will connect to the turbo.
whitestang5075
Feb 21, 2008 10:41 AM
