overheating advise
Old Nov 1, 2006 | 07:43 PM
molotov's Avatar
Default overheating advise
First of all I've already seach and have not find any help. So guys I've been having some problems with my GST that I recently bought. First of all the car was sit for about one year. Now that I'm driving the car it overheats every time I get out of the freeway. The gauge needle goes up to 3/4 near the red line. I took out the thermostat, and did a radiator flush and it still doing the same thing. My question is this should I replace the radiator and put a thermostat or just put the new radiator with out the thermostat. If any one can advise me thanks..
Old Nov 1, 2006 | 07:49 PM
5Tizzle's Avatar
Default RE: overheating advise
unless your radiator is leaking, there is no reason to replace it. Try replacing coolant temp sensors.
Old Nov 1, 2006 | 08:32 PM
molotov's Avatar
Well the radiator is not leaking, but the water boils.. Do you think the radiator might be plug cause when I flush it for the first time the water was very dirty like corroded..
Old Nov 1, 2006 | 08:43 PM
Does your fan come on???
Old Nov 1, 2006 | 08:47 PM
molotov's Avatar
yes both of them are fine..
Old Nov 2, 2006 | 10:59 AM
are you getting any smoke.
Old Nov 2, 2006 | 05:39 PM
DSMTalonAWD51's Avatar
replace the radiator cap, its not holding pressure-water boils and car overheats.
Old Nov 4, 2006 | 09:35 PM
molotov's Avatar
no I don't get any smoke. I'm going to replace the radiator cap $ see what happends
Old Nov 5, 2006 | 08:44 PM
molotov's Avatar
The car is still doing the same thing.. what else should I do..
Old Nov 5, 2006 | 09:08 PM
PooT_Nation's Avatar
are you leaking/low on oil? out in left field question but ::Shrugs:: it could be the case. i know my car runs a little hotter when i don't change the oil fast enough.
