P0300/ vac leak
ok my car just threw this code how do i fix it and what causes it? one thing is i know i have a vac leak somewhere-how much would a shop charge to fix it? and what is the reason i am throwing this code?
The hissing sound is more than likely from the intake, somewhat normal.
I just told you what the problem is.
If for some freak chance that it actually is a vac leak, it would cost how ever long it takes to find the leak. Im 90% sure that its not that.
it will run like crap if its a big enough leak.. I would personally try finding the leak first then see if it gets better.. It could be just running to rich and foul the plugs out.. So even if you replace the plugs it could just keep happening..
its not a boost leak its just a vac leak some where i think. but i was reading in another page that a vac leak would cause these simptoms 2 that is y i think its a vac leak. i will try the plugs first
